my 14' tom boy project
varns
Re: my 14' tom boy project
Well i was thinking of just touching up the nicks and scratches. Then do the entire inside withe gel coat, paint finally a clear coat. Yes he has done some gel coating.
Woodonglass
OK. Only use wax in the final coat of Gel. Make sure all blemishes are filled and faired. On the Deck, I'd Roll the gelcoat. Gives it a bit of a texture which kinda gives it a Non Skid effect.
Woodonglass
VARNS
varns
Thanks guys it felt good putting the deck in for my trial fit. Im getting so close to putting her back in the water. Got stuck moving my brother and grandmother this weekend so i may not get alot done ..mabey get the bilge cut out of the deck and drill some weep holes
varns
okay so i was trying to decide if i have enough resin left to finish her i have almost 2 gal. left. I have roughly 10ft of deck thats not quite 4 ft wide still need to coat both sides with csm also two layers of csm after i screw it down. Also install the original seats and live well will i need a third gallon? I dont want to over order also dont want to be short..one other thing on drilling my weep holes since my stringers are only 1" thick i was going to just drill 3/8'' holes how will i go about sealing these holes..any input would be helpful
Woodonglass
Your weep hole should be 1". Cut some 1" PVC and glue them in the holes with resin. Yer gunna need at least 5 gallons of resin to finish maybe 6. You gotta make PB too!!
varns
ok if i drill 1 inch holes in my stringers it will pretty much cut them in two they are only 1'' tall im guessing that is no big deal.. 5 gal. huh i thought you might say that. i dont want to have a bunch left over so im just going to order 3 single gal. instead of a full 5 gal. since i already have 2
varns
i think im going to have to go with more like 1/2''
varns
Since my stringers are so small i cant drill 1" weep holes im going with two 1/2" holes in each stringer its my only option at this point
Woodonglass
Yeah, I took a "Re-Look" and with the design of your stringers I'm not sure I'd put weep/limber holes in em. Did the original have em? could you tell? If so then go back with the same size as was there and if there were none then don't drill any. Your glass and sealing was far better than the factory and they'll last a whole lot longer than the originals.
varns
The originals stopped short of the transom im guessing for that reason i extended them after consulting with you mabey i sjould have just left them like original ..hmmm what to do im sorry i should have provided more info when asking about whether or not to extend the stringers i wasn't even thinking of weep holes
Woodonglass
Ok gotcha now. I would for sure drill some 1/2" holes back by the transom to allow the water to cross flow to the bilge. It will be fine.
varns
Cool im not planning on having much if any water under the deck. Im hoping to put the deck in this weekend caint wait she will begin to look like a boat again
varns
Deck side 1.jpgDay 1.jpg more pics the second is for you fstorm08 this is what she looked like the day i brought it home. I really like the original owners makeshift transom its great huh
varns
Im back i took a week break or so from the project. I had to spend some time with the family. The deck is all prepared and ready for installation as soon as i can get a hand putting her in ill post pictures tomorrow
varns
More progress deck down.jpg used some sand bags to hold the edges down made it easy to screw her down
