My 1966 Evinrude 60hp motor starts for a bit but then stops
khelhelou
Hi im planning on going out fishing on sat and i was testing out my motor so that i know it works before i head out on sat, i started the engine the first time and it started great, i tested neutral revving, forward and reverse, all worked. Then 30 minutes later i tried it again but it wouldnt idle without me revving the motor. I put it in forward and revved it and when i stopped the motor turned off. Any ideas? Does it need to warm up before it gets going because of its age? its about 60 degrees today.
Daviet
Re: My 1966 Evinrude 60hp motor starts for a bit but then stops
Will it keep running if you keep pumping the primer bulb, maybe you have a fuel pump problem.
khelhelou
ill try it out tomorrow and post the video of the results, any other suggestions i should try while im testing it out?
khelhelou
I took the boat out today and tried out that pumping of the bulb and gave it good ventilation but still nothing...do i need to rebuild the carbs? im going to do it anyway because i already bought the kit from here, but could the carbs be causing it not to idle at low rpms?
khelhelou
Sure can! Your idle circuits probably have a bit of gunk/junk in them.
Ok ill rebuild them and post back what happens, I really new to boating and was just wondering if rebuilding the carbs was a easy, intermediate or hard job to do.i also bought a new impeller and gearcase seal kit are those extremely hard jobs to perform either
f.y.i. - I have both the parts and service manuals
