Corjen1
- Joined
- Aug 24, 2013
- 1,237
Thanks All for the comments.....yes my cagina is all healed up!!
So the practice chair is done sans the base which is PVC tubing.......this has been a definite learning experience. and dammit I wish I had listened to what I read and had been told experience!!!
So here is the back and bottom pads...What Ive learned here :
Piping: Not necessary to sew right up next to the welting in the initial fabrication, run a seam so it holds the welting in. When you sew the piping to the plate, then sew right up next to the piping.....it will prevent the thread showing when the cover is stretched over the base.
Plates/Boxing: When sewing the boxing to the plate, use alignment marks to keep them aligned properly to each other. My boxing seams are not even/centered left to right and front to back.
Cover installation: This was pretty straight forward.....except when cutting your foam, in my opinion, cut it at least 3/4 inch bigger than your base. This will give you a "fuller" look As you can see on mine, the corners look deflated. I also had to turn down the air pressure on my harbor freight stapler to where it would bearly drive the staples, on the normal pressure (100 psi) it was driving the staple completely through the vinyl.
I made one of these, I found out that thest type of thread spools are made to unwind from the top, not the side as a normal spool...
More on the next post....
