Re: My 1977 Intruder Aquarius rotten deck
So, round two begins the deck, stringer, transom tear out. What a mess! Tons of water weight sitting in the bottom. Keel stringer was free and moving inside the fiberlass covering.
Got everything cleared and abojut 95% ground and ready for new stringers. But, decided to flip hull and start working on gel coat patching first.
I will take more bottom hull pics soon, but there was a lot of automotive Bondo used to patch holes. Noticed some slight keel damage and saw the boat was not sitting on the rollers in the back. It was actually sitting on the axle. After pulling hull from trailer, it looks like the PO had duct taped a flip flop over the axle in the spot where the boat sat. Thought I had seen it all.
Anyway, due to the extensive gel coat damage, I decided to grind off all the gel coat on the bottom of the hull and the transom area. The sides will stay and be repaired accordingly. I would rather put the work in to grinding the crappy stuff off and starting new.
Transom appears to only have a solid piece of wood on the lower center part. I cannot believe the tow hooks did not rip the back off!
So my question at this point is.... when I finish the gel coat and outside hull, then get ready to bed stringers, would it be best to replace the old keel stringer with a 2 x 12 or with a laminated stringer made with 2 pieces of 3/4" arauco with 1 piece of 1/2 sandwiched in between?
