My 1994 wellcraft eclipse 210s overhull.
94eclipse
GOT IT ON CRAIGSLIST FOR 800 COMPLETE WITH THE FLOORS TAKEN OFF. GOING TO BE REDOING STRINGERS, FLOOR, MOTOR, AND AFTER EVERYTHING IS DONE CLEAN AND REDO SOME OF THE BAD INTERIOIR. HERE ARE SOME PICS.
after most of the foam and stringers were removed
the transome
engine back from the machine shop
heads
ezmobee
Re: My 1994 wellcraft eclipse 210s overhull.
Nice looking project, well worth the effort to fix up. Good luck with it!
94eclipse
got some stuff done today. most of the stringers and ribs are made up and i have cut out and removed most of the foam and stringers from under the bow area. its going to be a real pain to put all that and glass it under there. will get some new pics soon.
Friscoboater
I love that boat. It will be a similar built to my Sea Ray. We are here to help.
94eclipse
yea when i was watching your videos i was says damn that look just like my boat.im also going to be doing a stringer design like the one you have done because that boat had way to many strings and then fill it with foam for more support.....i will also like to thank you your videos have been very helpful, and i signed up here because of your videos.
94eclipse
got some work done on the wellcraft these past couple of days. i got the transome wraped and most of the rear stringers are completely wraped just need to be capped. here are some pics.
and what keeps me going the outside
94eclipse
this is a pic of glueing down the rest of the stringers. all that is already glassed in will get a pic of that later.also started putting the engine together but didnt go very far. only got the crank in.
ezmobee
Looking REAL solid. Nice work.
boatnut74
You are doing an excellent job and are making some great progress.
94eclipse
Here is a pic of all the stringers tabbed in.will try to finish all the glassing tomorrow but is very hard to do for along time because fiberglass gets stuck to everything.
Getting the pistons pressed on on Monday so I can keep building the motor.
94eclipse
Here is a pic of the stringers all capped..... It's is like impossible not to get air bubbles when you cap them.
94eclipse
Here is a pic of the two long pieces test fitted. Tomorrow I will be doing the front piece and the piece for the gas tank.
SouthTexan
That is some nice looking work there! Making great time too... makes me want to get off my butt and go get some progress made!
ingalp01
Looking very good so far... Nice starter boat too, finding one that is ready to be restoed is nice... Keep it up and keep the posts coming...
94eclipse
Thanks can't wait till I'm done so I can have my life back and enjoy the boat.
Friscoboater
Very nice man. That looks to be stringer than my boat.
94eclipse
Cut the rest of the deck yesterday. Will be sealing the bottom of the floor with cloth today to glass in the floor this weekend. Going to buy the foam hopefully today.
And here is the intake. Still looking for a heatexchanger.
94eclipse
Worked for about 8 hours today. Got most of the foam done and installed gas tank and screwed,glued, and pb the sides of the floor. Also got the pistons back finally so will start building Monday. I have aliitle of everything on my body. Foam,glue,resin,pb.
94eclipse
Got all the floor in today. Will start glassing it tomorrow.
