Re: My 2000 16' Sylvan Expedition Project
Things I learned that I hope others will take note of and use in their builds
1) I measured very carefully and used old pieces as templates but if you are going from carpet to a roll on type coating, take the thickness of the carpet into account. You can see the piece of plywood I had to rip down and screw in to fill a 5/8" gap.
2) I put all my durabak on first, next time I would reassemble then use the durabak, all seams and rivets/screws would be hidden.
3) for a boat this size you really need 2 gal of durabak. I have another one arrive today and will put 2 more coats on all the visible deck surfaces to hide all the seams, fill in any gaps, cover the screws rivets.
4) hatches are a pain in the ***...I picked up some rubber weather stripping to put in the hatches tonight, that will tighten them up and keep them from rattling.
my materials list for this project was
2 sheets 1/2" AC exterior ply
2 sheets of 3/4" AC ext ply
1 gal spar varnish
1 2# kit of Gluvit
2 gal durabak UV textured
misc rollers, brushes, wire wheel, nuts bolts screws weather stripping etc.
JB weld, 1 tube of PL premium and 1 tube of 5200.
I will not tear this boat apart again, any questionable areas got extra gluvit, coats of JB weld, and filled a bunch of areas with 5200 or PL premium. Overkill under there.
When you gluvit along your ribs, make sure you leave a spot for the water to run under the rib to the bilge, I coated them all and the gluvit sealed them and water had to flow over the rib like and ice cube tray. As far as I can see now, any water that does get in (hopefully none) can run right back to the bilge for the pump to pick up. This alone should keep the decks and foam in MUCH better shape than the factory build.
I hope the gray looks better but only time will tell.
