Re: my 68 Starcraft Holiday project
Ok..so the reason she wouldnt start was ohhhh..10 years of green goo blocking my brass outlet at the bottom of the fuel pump..AND had the same green goo at the brass inlet to the carb...
Soooooo..When I bought her, she fired right up....I guess the guy that had her either loaded her up with gas down the carb or fogged the cra
outt her with starting fluid....
But a couple days later when I got her home she fired right up again...Musta been a pint of gas down the carb....
I cleaned out both fitting pretty good...have em soaking in cleaner for now...
My other frustrating thing to day was the business end of my shift cable..
The old cable has this spring bolt/cotter pin set up...
I think OK, I'll pull out the pin and pop this huckleberry on my new cable..
Ya...maybe not. Was going to jerry rig it with a longer bolt or something..
My guess is that the spring is a shock absorber for flexing during the gear changes from fwd to rvse..I posted in the I/O section and dont have any info yet..(slackers..lol)
