My 70 Evinrude, the VRO and trolling...........
joetheis
I purchased a 1991 Grumman 18' Fish n Fun boat with a Evinrude 70 HP hanging off the back.
I bought THIS boat for 2 reasons, 1) the 70 HP HAS to be pretty good on fuel, and 2) this is a more "pure fishing boat" than my 20' cuddy.
It has the VRO fuel delivery system.
I read good and bad things, but most bad I've been able to pick apart as another problem that was blamed on the VRO.
I just read a GOOD acticle on the VRO from, http;//continueswave.com/whaler/reference/VRO.html.
Expains what as a mechanic and a fustrated would be engineer needs to know what is going on and how it all works.
My concern is this.
The motor runs at 50:1 mix at WOT.
Understandable.
But 99% of the time I want to run at low RPM, (trolling st 2-2.5 mph)
This should be at a 100:1 mix., (I've had trials bikes that run 100:1 as well as a Yamaha "kicker" motor on my sailboat)
Will running at idle or a bit above over long periods burn a piston cuz it lean?
Has anyone ever ran a VRO motor like I want to?
I could just unhook it and run 50:1 in the tank, (he give a great maintenance advice on oil tank and fuel, that really when he says it, makes perfect sense), but it's running great now, (I've yet to really use it, just a few quicks trips out and back to see how it ran.
It's a system that motorcycles, snow mobiles have used for a long time and as all things mechanical, "when it works, it works great, when it breaks, well...."
Thanks!
Joe
flyingscott
VRO stands for variable ratio oiling at an idle I think yours runs 80 or 100/1 as you speed up the mixture gets richer ending up at 50/1 so don't worry about it. The only thing I would check is make sure you have the most up to date vro a dealer can tell you that. The vro is a good system and is the only one that has the no oil flow warning.
64osby
You could always get a kicker that is made to putter around. Quick simple and easy if you get a 4 stroke.
joetheis
I have a great 9.9 hanging off the back of my 20' cuddy I'm gonna sell!
My thoughts exactly!!
But, that Mariner motor is mix, sooooo, I'm gonna put the VOR on stand by and mix my tank 50:1, so I won't have a small tank flopping @ on deck!
But, was wondering given the system, IF a 100:1 at idle is a scary thing??? (I figure they MUST know what they are doing- but sometimes Engineers are pretty stupid)!!
Run it yesterday, really rich on bottom, and faster idle than I can troll with.
Lettem ask you............
Any pics of your steering set up, (i have a good working one on my outdrive-but have to start over on this motor)
Joe
