Re: My 90HP Pics
Mnemonic, Let me guess, you run in salt water, correct? Your best bet is to replace the "triple clamp" with one from the junk yard. The part should be readily available since I think it was the same fro many years for all 4 and 6 cylinder models.<br /><br />It is a bit of work though. I had my mounting shaft crack under the PT&T lower mount. I was able to weld it though.
