My boat took on a lot of water and now it doesn't want to stay running
caerickson
I just got my boat out of the shop and it was running great. Then the water level was raised and a bunch of waves crashed over my boat. I ran the bilge while I tried to get my boat off the beach. So I don't know exactly how much water it took on. When I got it off shore, it started right up. But after a mile or so it was losing power and eventually died. I got it back to the launch and tried it the next day after I let things air out a bit. It would start up but would die if I didn't give it quite a bit of gas. Does anyone have any ideas about what I should do?
Re: My boat took on a lot of water and now it doesn't want to stay running
Ayuh,... It's loosin' it's Fuel, or it's Fire,.... diagnose Which,...
I suspect Anchor might be Right...
caerickson
Ok, thanks. I'll check the gas out first.
caerickson
Yeah, I think that did it. I sucked the gas out and there was some water in it. Thanks for the tip.
jtmarten
Drain the carb bowl(s) too. Most likely lots of water there too.
caerickson
ok, will do. thanks
