My budy is giving me a garden tractor
Jeff-in-PA
Re: My budy is giving me a garden tractor
NYbo,
If you're giving away any more Cub Cadet's , email me. Have trailer will travel :D
Jeeperman,
GREAT picture. ( I wish my 125 looked that nice ). Pretty sure no more powdered lead in the tires.
Can I copy and post that picture on the cub cadet forum?
Thanks
Jeff
mrdancer
There is a HUGE difference between a GARDEN tractor and a LAWN tractor. If it is truly a garden tractor he is giving you, then you should be OK. If it is a lawn tractor, then there is a good chance you may not be OK. The lawn tractors are built much lighter/cheaper with weaker transmissions.
HP means very little when it comes to the quality of a good garden tractor. If it is a high-quality tractor, then it has already been designed with sufficient HP to handle any job it was designed to do.
It is all about traction and the ability to get the power to the ground (with a transmission strong enough to handle it). Here is an example: My Dad's late 1930's "B" John Deere, considered a row crop tractor (a step or two above a garden tractor), weighs in somewhere around just under two tons, has a real transmission with gears (4 forward, 1 reverse), a two-cylinder 190c.i. engine that produces a whopping 16hp with 4.7:1 compression when new. At close to 75 years old, it will still outpull ANY tractor you can buy at any Big Box store, and do it MUCH faster.
If you want a REAL tractor that is still pretty small, check out the CUTs (compact utility tractors). They are about the size, or slightly larger, than a garden tractor, but built much better. They will run you upwards of $10k for a good one.
sqbtr
I was the king of the neighborhood last year when we had the big dump.
127 cub, wheel weights, chains, and an original narrow frame snow plow, it does have head lights and LED tail lights. If I could lust find a cab :D
Then there's the 102 puller, or the 125 mower. No need to change attachments. Just get on the other tractor. Did I mention the series 4 Snapper rear engine rider completely restored with the bagger atachment
Grumman59
...Did I mention the series 4 Snapper rear engine rider completely restored with the bagger atachment
I can move my 18' 3000lb Doral around with my 1964 5hp Snapper Comet 26 if I need to but my old big frame '67 MTD Ten Hundred will pull just about anything with its 10HP B&S Cast Iron engine and crawler plough gear.
bobdec
My 20 HP Craftsman is not a tractor so it only has one brake disk mounted on the drive shaft input to the rear end. (AKA: one wheel braking) So when one wheel looses traction during braking the other spins backwards thru the differential. Quite a few times on wet grass I've lost braking and/or low gear hold going down steep slopes. Would not want that to happen with a 2000lb boat and trailer behind me..It may pull and steer, but don't overlook stopping..
