Puzzled look
Thread starter- Joined
- Jun 3, 2009
- 36
I have a 90hp Johnson V4 2 stroke engine on my rib. I have recently bought the rib so am new to this type of engine.
I not sure of an exact age but its around late 1990's early 2000. I think it was new with the boat which is a 2000 model.
When I bought the boat the engine had just been serviced so I'm not sure why it wont idle. I suspect that the revs just need turning up a bit.
The engine controls have a Small lever next to the throttle lever this is what you use when starting the engine. It starts fine and ticks over but when you close the lever to engage gear with the throttle it stalls.
You can (if your quick) close the lever and engage forward gear with the throttle and the engine labours in to life but as I'm sure you will agree this is far from Ideal. Has any one any ideas to trouble shoot?
I can post a photo of the engine if required but this will take me a while as the boat is kept at a holiday cottage.
Many thanks
Many thanks
