coolbri70
Thread starter- Joined
- Oct 6, 2011
- 1,554
i was out on the river doing some boating today, the motor was running great and i let the misses drive so i could verify a problem with my set up, i looked over the transom to see if this plate was on top of the water at wot planed off,
it was a couple inches under water and i was told it should be just above the surface and that if not the motor needs raised on the transom. then i left her continue drive as it looked like she was having fun, when she was done she stopped and i took over, but when i went to take off i noticed the power was gone it would hardly plane, it would not get 3000 rpm, she was worried said she was sorry she broke the boat, i told her it would be fine i would figure it out when we get it home:facepalm:. so i get home pull off the cover and noticed this lever with nothing attached then noticed this rod hanging, i popped it back in its socket.
i'm thinking this is a timing advance
if so it could have been the issue, did i hook it back up correctly
