My first prop change!
atlapp
I am restoring an old pontoon boat....the motor is a 78 model 70hp johnson...it currently has a 17 pitch prop, I have ordered and 11 pitch prop from a Solas dealer...my question is do I have to replace hub assemly, as the one that is on the boat appears in excellent condition?
John_S
Re: My first prop change!
Solas makes replaceable and non replaceable hubs. In general, hubs are only replaceable between the same brands/models. Some kits you buy do require you to use the original thrust washer, etc. Even if you have a hub match, I would just install the new one with the new prop. Keep the existing prop/hub for emergency spare, until you get another with the lower pitch you need.
