My First StarCraft; 1975 18' SuperSport
classiccat
Re: My First StarCraft; 1975 18' SuperSport
4.) Make the bend and check that you're 90-degrees with a square.
5.) Put the brace in position & mark the shelf (should be ~ 7/8")...this is the outer tab. Line-it-up in the brace...paying attention to where your clamps go; the outer tab is going to swing-towards the clamp.
astor
2018's Starmada Splash Of The Year.
BF are you going to tie it all together with another long piece of aluminum screwed to the deck and riveted to each Z bracket
Pink foam could also be placed between the Z brackets for additional floatation.
classiccat
Hey Astor...stuffing foaming into that empty cavity is in the plan!
The side panel assembly will serve the purpose of the aluminum that you describe.
Thanks for stoppin' by!
ctswf
Hi blue, can you show the break tool you're using? I have access to two different 8' breaks used for trimming windows, I recall testing a piece of 0.04 and it looked like there was no chance in bending it.
classiccat
Hey Ct, it's the 30" Bending Brake from HF. you place the piece you're working on under that heavy piece of stock and clamp it down with some heavy c-clamps & wood blocks. zero complaints so far!
ctswf
thanks i just checked it out, had no idea its only $60, i might have to pick one up when my mbs picks up around march
classiccat
Yep, its on sale; normally $100. It is still Christmas! ;)
at that price, it's hard to beat...it will pay for itself quickly if you fab your own channel, angles, braces, brackets, etc. :thumb:
You'll need some big c-clamps. In my illustrations above, I only use the irwin clamps to temporarily hold the piece until I get it clamped.
Watermann
Yeah I'm thinking I need one of those brakes to add to my tool collection.
classiccat
tin heads definitely have the cooler tools! :cool:
astor
LOL, I think we do, always looking for that excuse to purchase a "necessary tool"
go look at the harbor freight website, there is the annual 25% off coupon for Jan 1st. I may have to print off two and have the wife go shopping with me. I think I need that lil brake, and maybe a set of HVLP sprayers.
classiccat
well fellas...ive joined the darkside! :eek: no i didnt buy a glasser...im updating this thread on a smartphone! funny bc im part of the team that developed the technology that went into this phone's microprocessor! kamsa hamni da :cool: anyways besides not getting funny looks when i whip out my dumbphone at meetings...i can make updates from the hanger! yay! ...which is also at 49 degrees...perfect temp for the craft beer that im currently enjoying :cool:
now if only jas will develop an iboats app for android...cough cough ;)
classiccat
i hope to eventually figure out how to plug in multiple images from photobucket :)
fabbed the tabs that lock the shelf to the vertical risers;
GA_Boater
Would that be open as in open source code or as in cut the top off a tinny? :D
classiccat
holy tinny!
my fishing partner will be arriving in 4 days for bucking bar duty!
classiccat
bahaha! im on the hardware side of the biz...so i add tin to my boats :p
GA_Boater
You're gonna need a bigger bilge pump. :D Not a problem in a few more days. :)
Watermann
Great ideas being put into practice here, man your SS is gonna be solid and crack free.
classiccat
approximately 445 holes below the waterline...plus the thru-hull corrosion...and another 50+ above the waterline :eek: i'll let u do the math on how many gph would be adequate :nerd: :lol:
thanks waterman! im happy with the way that it's all tying together. :thumb:
ctswf
top 3 life changers of a smart phone: maps, restaurant phone numbers, and looking at starcrafts all day :)
jbcurt00
Yeah, there's an app for that.
