classiccat
Thread starter- Joined
- Dec 20, 2010
- 3,412
Once the strip is screwed in place from 1 side, I was able to start going to town with the dead-blow, starting at edge where it's screwed-in...getting the aluminum strip to conform to the keel. As I was doing this, I had to keep tightening down the 8/32's since the gap between the alum patch & keel would close-up.
Once I got it to the other side, drill/tap/screw more 8/32's in place.
This is the time to get all of the finish-pounding in because you can always tighten the screws back-up if they're made loose. You're s.o.l. if a blind-rivet loosens-up.
Like flattening the ends down with the riveting hammer:
The final stretch is putting-in the closed-end blind rivets (All aluminum).
^^^ the results exceeded my expectations by a mile!
Thanks for stoppin' by! :yo:
