My gear shift cable end fix
bashr52
The old plastic end on my gear shift cable finally broke on my 1960 Lark 2. I looked on ebay and online to try and source one, but couldnt really find what I needed, so I made my own. It has exactly the same dimensions as the old one, only this one is steel :) I shouldnt have to worry about it ever again.
Old one on top, new on the bottom.
samo_ott
Re: My gear shift cable end fix
Looks good. Have you tried it yet? My question is how did you get that little knurled push and turn piece (for lack of a better term) at the end through as it has the tiny locking pin at the end. Did you get that little pin out? Or machine a bigger hole for the pin to fit through?
bashr52
Yes tried it and it works perfect. The pin in the turn and lock piece is a press fit roll pin. It is knureled in the middle to keep it in place. I just tapped it out with a punch, pushed it through the hole, and put the pin back in.
bashr52
Thanks, but that looks more the like cable end for the throttle assembly. This one works and I never have to worry about it breaking. Plus, besides some time, it was free! :D
