SkiDad
Thread starter- Joined
- Jul 18, 2010
- 1,518
Hi Guys,
My engine has always started easy the 1st time each day and generally starts easy when on the water. Will always re-start 1st turn if I put it into fast idle. But usually will take 2 turns to restart when switching skiers if I just re-start it without fast idle.
When I start it cold its about 1500 for a minute - i wait until 1200 before I put it into reverse. One of the things I noticed is that my idle never seems to be the same RPM when I re-start it later. It will start out between 700-1200 in neutral and anywhere from 700-900 once in gear. If my engine starts at 700 rpm in neutral I wait about 10 seconds and it will creep up 900 and then I can put it into gear fine. This rpm fluctuation will happen every time we switch skiers and there is really only 2 or 3 minutes between off and re-start. I never know if it will be high or low. Obviously no issues if it starts higher like 1200. I don't understand the reason the the varying idles It's something I've always fought on this thing and it seems you really have to mess with the idle speed just to find a spot that is a happy medium for what ever mood the engine is in.
Sometimes when I stop after a long ski run it and go to neutral my rpm will be about 1500 for a minute (this is before I shut it off)
hit the gas and I'm gone and it runs like a champ and any speed... will even idles for an hour with no issues if I'm just cruising at night.
