my install of the transom in 27 deg weather
lime4x4
Re: my install of the transom in 27 deg weather
yeah the only thing that worried me at first was the white spots in the fiberglass. First i thought it didn't soak up enough resin. But when i applied more resin the color never changed. Then i thought maybe it was trapped air. But no matter how many times i went over it with a roller it never changed. So i'm going to assume it's just the way it is.
lime4x4
here's a couple of pics of the supplies and foam pouring
foam pouring
SuperNova
You know, when you first bought that boat, I figured you'd change the name.....now I think it's just fine....fit's I'd say...
lime4x4
so what is it your saying????
SuperNova
Why nothing....nothing at all.....:D......and by that I mean that the steak and corn and potatoes tasted GREAT!!...So did the rum and cokes and such....
osborn159
looking good, especially dealing w/ the weather as you are, coming along nice,
keep at it.
D
lime4x4
Engine will be in this weekend and on the water the week after
Finally light at the end of the tunnel..lol
lime4x4
engine installed.electric fuel pump wired,battery switch installed and blower wired
ezmobee
Looking great Lime!
lime4x4
a couple of pics of it on the water
lime4x4
I figured while i was in there i was going to replace the freshwater lines. Decided to use pextubing.
Friscoboater
Awesome job! It feels great to get back out on the water huh?
Robert4Winns
Looks great. Congratulations on getting it done in time for this season.
lime4x4
Yes it's great to be on the water.. Still have alot to do yet. Gotta finish recovering the seats. Some wiring and very good cleaning of the whole boat
Shife
The white areas are resin starved. Looks as though the substrate wasn't wet enough when the glass was applied. Not much you can do about it now. To prevent this go heavy on the resin and cover with peel ply to prevent over saturation. In those temps you should really be controlling the climate on both sides of the laminate and vacuum bagging for the entire cure cylcle.
I've had some odd things happen when working with West in temps below 40f. This was on a tented boat running a salamander. I certainly wouldn't recommend it as I had to redo some areas where the laminate cured just fine, but the secondary bond with the substrate was abysmal. I would wait for better/more consistent weather before slinging that many dollars worth of West.
Are you keeping your cans in a cooler with a light bulb in it to keep them warm? You really need to be in those temps.
tinkeringwackyone
Glad to see another project back on the water. gives me inspiration. congrats
lime4x4
It just gets better and better...I wonder where it's going to end...lol I decided today was the day to finish installing new vinyl on the boat. When i removed the port side panels no rot was found. Removed the starboard panel and the wood that helps hold the radar arch on is mush.. Atleast it's an easy fix
lime4x4
Just an update. The boat now stays on plane at 3300 rpm's 25 mph according to gps and only sucking up 13.01 gallons of fuel per hour. Before it would stay on plane at 3800 rpm's speed 25 mph with a fuel burn of 18.89 gallons an hour. So basically i'm saving an extra 6 gallons of fuel per hour.. So in my opinion it was well worth doing.. Just got a lowrance hds-5m gps/plotter for the cheseapeke bay area. So now i have to learn how to use that...lol
