captaingaff
Thread starter- Joined
- Jan 21, 2010
- 5
I have learned so much from this site but this is my first post. One thing I notice is that knowone ever posts how there problem was resolved... believe me if you guys can help I'll be sure to let u know what happened..this originally a 1997 90hp SPL but was rebuilt with a late 80's block...maybe 110hp??? twin powerpack...anyways...
2 months ago i was runnin WOT and she drop a cylinder...started poor mans troubleshooting which has always worked in the past...visual inspection of spark and swaping out has always faithfully led me to bad coil, plug wire or plug...not this time...i narrowed it to the wire from the PP to the bottom starboard cylinder...tryn to cut time to make a fishin trip I jumped the gun and bought a new PP and replaced all spark plugs...still no spark on that cylinder...swapped PPs and dremeled ALL grounds...sparks on all cylinders!!! Ran great for 20 min on all 4...then died...like key was turned off!!! no restart...towed in..now both on 2 port side cylinders wont spark...it followed the brand new pack...bought ANOTHER pack AND replaced timer base plugs AND had resistance tests done on stator and timer base...all sparked good...took it out..ran great on all 4 then it died in almost the same spot...but restarted this time and i limped home w/ 8mph top speed...didnt check spark...read some more posts on here and figured it must be my stator...bought a used stator...started good...idled out of the canal...but again wouldnt jump up on plane...limped home...didnt check spark...read more posts...gettn pretty good at poppn that flywheel off so i decided to trade my used stator for a used timer base...but tmrw is when Im gonna install and test it...but could a timer base be intermittent like that if the resistance tests good??? Gonna get a spark tester tmrw...I know my procedures are p!ss-poor at best but Ive had this boat for alot of years and feel pretty confident that plugs,wires,coils, pp, and stator are not the issue...any other points in the right direction would be appreciated...rectifier??? grouper season is gettn ready to close for 2 months...help!!!
