Brentathon
Thread starter- Joined
- Dec 29, 2009
- 399
Well, I successfully dis-assembled everything, and replaced both bushings (large & small) and the seal for my Upper Swivel Shaft on my Alpha Gen I.
I will then assemble everything, using my new SS (J&R) swivel shaft. I did this through the access holes drilled into the gimbal housing.
Question: Does/Did anyone still use grease on the Swivel Shaft where it rides in these two bushings, OR is that detrimental to the coating ("permalube"?) that's on the I.D. of the bushings? Being that the condition of the original bushings were REALLY bad (i.e. very worn), I would like to prolong the life of these new ones, as much as possible. I'm skeptical on this anti-friction coating, on them......
