I have a 92 Mariner Magnum III 150. This past weekend I throttled back sharply while pulling a tube and the motor stalled. When I went to restart the motor was locked tight. I could not turn the motor over by hand forward. I was able to turn the motor over by hand in reverse and it moved. I then turned it forward and it moved freely and even restarted. I'm guessing I did some damage somewhere. Is this normal or should I be looking for something? I was going to do a compression check to see if I bent a rod. I did notice a slight water leak out of one of the cylinder heads but no water in any of the cylinders.
