My older motor died. Might be able to fix it, but probably going shopping.
DJ_Allatoona
1986 Mercury 75HP. Serial #0A984714. After eleven years of mostly rock-solid service, something very serious-sounding happened the other day. I launched and idled fine, then crept out of my creek at no-wake speed for about 15 minutes.
When I throttled up out of the hole, I knew immediately something was off. RPMs and power were normal, but there was a metallic rattle sound and high-speed knocking. Throttled back to about 25% and it stopped. OK, it's a cold morning, and this motor sometimes does random things and makes random noises that come and go. I didn't turn around.
Gave it a few minutes, then throttled up again to about 50%. The sound was back louder, accompanied by a fast vibration, shaking, grinding, and a funny 'slipping' feel in the propulsion. Definitely something was spinning off-center and knocking metal. Before I could get back down to idle, a solid THUNK and it shut off.
Pondered life for a few minutes, tried the key again and got a powered click from the starter, but there was resistance and nothing turning. Seized. Electrics all worked so I tilted up, paddled toward home until a good Samaritan towed me in.
My thought is one or both of the drive shaft bearings failed, because of the off-center spinning feel and grinding sound. I won't be able to drop the lower unit for another few days, but best-case scenario is I can fix this as a fall project.
Worst-case, I never bought JUST a motor before, and I cannot believe the prices out there, even for older motors that need work. I see a lot of fully-rigged boats for cheaper than just a motor. Amazing.
Anybody got thoughts on my dead motor? And where would you start looking for a used motor if you were me? I'm in Georgia.
Faztbullet
Check the gear oil for metal as it may have chit the gears....cheap fix if that's what happened.
If lower unit gears are broken then a used lower unit is an easy fix.-----Lots of those around.
DJ_Allatoona
Ah, gotcha. I wasn't thinking bigger than fixing INSIDE the lower unit. Yes, replacing the whole thing seems like an easier route.
