Re: My PC is messed up. Can't open files
OK,....it's not too big of a deal to find a solution if you can provide just a wee bit of info.<br /><br />What is the file 'type' (hint: is it a txt file, a doc file ect....)<br /><br />What Operating System are you running??? (hint: Win98, Win2000, WinXP)<br /><br />It sounds like the file association for that 'type' of file is mis-configured....<br /><br />Usually HTML documents (saved web pages) open with your default browser....<br /><br />If it's a xxx.txt file, it opens with Notepad etc.<br /><br /><br />Edit: woops, just saw, Win98....<br /><br />Try this,<br />Run WIndows Explorer<br />At top menu, pick Tools, folder options, file types<br />Look up the 'file type' in the list<br />Look to see it AOL.exe is listed to handle this file type.<br />If AOL.exe is not listed, browse to the folder where AOL is installed and click on Aol.exe and click OK.<br /><br />The point here is to determine what the 'file type' is for sure...<br /><br />What is the full file name of the file you are trying to open??
