LaqueRatt
Thread starter- Joined
- Jun 27, 2022
- 492
Boy the previous owner, a lady school teacher, really told me a story when I bought my boat. Said they'd had it on the water a few days before and all was well, except, of course it needed the "carb cleaned." Has there ever been a motor sold that wasn't said to need the carb cleaned? If it were only that easy. All signs seem to point to this poor motor being abused and neglected.
So far, I've replaced the points, condensers, coils. Timed it and set the dwell. Replaced gasket on leaky fuel pump and cleaned screen.. Replaced the fuel lines. Flushed the tank, cleaned the strainer, repaired leak at the elbow, twice. Replaced one quick connector. Had the carb off for cleaning twice.
Have had it out on the water 4x and it crapped out on me every time. Even though is seemed to run well in the barrel. Going to try it again today. You guys have told me what a good, reliable, strong motor the 18 is and I believe it. Just hope if get the damned thing sorted out it will be serve me well for awhile. So here's my notes from yesterday:
Cleaned the carb again. Didn't look dirty.
Started right up.
Ran decent, no coughing.
Adj low speed jet for best performance.
Ran for 12 minutes.
Started coughing and died.
Wouldn't restart.
Checked for spark. No problem.
Sprayed fuel into the cylinders.
Ran for a few seconds.
No restart.
Added 3 oz SeaFoam to 3 gals fuel.
10 minutes or so and she starts back up.
Running fine. Burbling nicely at low RPMs.
Thinking it may be getting hot, lasered the heads: 125-135
Ran awhile, started coughing and same crap.
Checked fuel pump. 12 pulls got me about a shot glass worth.
Finally got it restarted and ran for 45 mins as I played with the adj screw.
Idling and accelerating smoothly now.
Seems like it will run as long as I want it to and starts right up.
Guess it's time to take it to the lake again, but my confidence is not high......
Think I'm good now? I just can't imagine what I'm missing. It has really good compression too. Any thoughts or comments would be greatly appreciated. I've worked on most every kind of engine in my life, but never an outboard before.
Started right up.
Ran for 12 minutes.
Wouldn't restart.
No restart.
