my pressure tester cannot be put into the cylinder.
liusigou
Today I tried to have a test for OMC2.3L cylinder pressure. But my pressure tester cannot be put into the cylinder. I did the testing with mercruiser 2.5 L motor. Why does not work for OMC motor? I checked the diameter for my tester and the spark ,they are in the same size.
liusigou
Attached files showed the size are the same
liusigou
What kind of tester should I apply for OMC engine cylinder pressure testing?
liusigou
I went to Canadire tire to rent another tester and it worked. It has a longer adapter.
