my prop is bleeding
coolbri70
run the motor on muffs yesterday today grease puddle under my prop
coolbri70
Re: my prop is bleeding
im no expert but im thinking this is a bad thing
coolbri70
im thinking a seal maybe? guess i should check my lower unit oil to see if its milky from inside or did it get that way after it leaked out
coolbri70
it is a 1979 85 hp evinrude by the way, any suggestchins?
Davem3
need more intel, please?
heck the model number would be gold.
it could just be normal oil coming out and the excess does come out there, exhaust does come out the prop.
i think it is supposed to be a 50:1 mixture for the motor.
anyways, drain the LU, look for water in the oil, go from there.............
coolbri70
its a 2 stroke i did mix a little rich was thinking to err on the safe side is this a bad plan? i will check the lower unit and degrease the prop to see if it comes back
Daviet
That is not abnormal if you are running it on muffs, especially if you have the fuel mixture rich on oil.
Check the lower unit to make sure there is no water in it.
Davem3
nah, not really, all you will do is foul the plugs faster and have a little more smoke, AKA james bond, lol
check the LU grease, just to be safe ................
when was the water pump last done ???
rockyrude
Mixing rich is better than lean. Agreed check the lower unit lube for water in the oil. Don't forget, all the oil in the fuel doesn't get burned, some goes out the exhaust. Since water is going out the prop also, some of the unburned oil mixes with the water causing milk on the muffs. Unfortunately on the lake, it just sinks to the bottom.
coolbri70
thanks i hope its just that:facepalm: the model number is 85995R. i've worked on this boat for a year and a half feel like i could barf, hasnt even made it to the water yet. think i will take some degreaser to it also if its a seal the grease will return i think:confused: yes i will pull the drain screw also if there is water in the lower it would be on the bottom as oil floats?
Daviet
Yes, pull the drain screw on the bottom, water will come out first if there is any in there.
coolbri70
the impeller is due, the PO did it just before i bought it:eek: i was going to do before running it in the lake, i was running it to see how it runs figured since it was squirting out the telltale it might be ok to run
coolbri70
thanks again this forum is a godsend you guys are great:redface:
coolbri70
ok so i sampled the lower fluid1337561815156.jpg1337561922063.jpg1337562044608.jpg it looks golden in color im thinking a good thing:confused: i hope.
coolbri70
now im wondering since it was running on muffs and not submerged could it still be possible the seal is leaking out and not getting into the lower unit?
coolbri70
i was so upset earlier i pulled it from the driveway back into the back yard as i was sure boating season was over for me this year before i even started:facepalm: i allmost cried then i drank a beer something i havent done since my wife passed away 6 years ago
63Sport16
If you want to satisfy your curiosity about the lower unit, just have a vacuum/pressure test done it. It's pretty simple and a tech can do that under an hour easily.
coolbri70
thanks for the idea i did not think of that:facepalm: i am a tech :redface: i will bring my vacuum pump home from work tomorrow and see if it holds :rolleyes: that beer i had gots me buzzin, feeling foolish now
63Sport16
Don't over pressurize the unit. Remove the gear case drain plug and drain the lower unit. This is where you will also insert the connection of the pressure tester pump. Make sure when you insert the pump that it has a rubber seal on it's seat face so you don't get a leak at that connection.
Start with 3-6 lbs and see if it holds for at least 15 minutes. If it does, increase pressure to 16 to 18 lbs. and see if it holds for at least 15 minutes. If it doesn't hold at either range, submerge the unit in water and watch for the air bubbles to see if you can detect where the leak is. I do both vacuum (same pressure readings) and pressure tests because the seals are dual purpose. Like a two way gate. They are made with a tapered lip on both sides.
Pressure from either inside or outside puts pressure on the lip forcing it into the shafts. But if one of the seal lips are damaged, the opposite seal lip will give way as the reverse pressure on that seal lip can allow air/water to push past it with dramatically lesser effort.
