My Rhino V176 All Alum Suzuki 4 Stroke Df-70
BASSNUT67
New to the board just wanted to share
One day I get a call from my Dad in Alabama he tells me he is getting to old to handle his boat and he is making arrangements to have it delivered to me. The boat has been sitting for about 2 ? years. The boat arrived on 11/05/07. Woke up early Sat morning and started cleaning all the seats, after I got done with the seats I put lots of vinyl conditioner on the seats DAM THEY TURNED OUT AWESOME. Today I shampooed all the carpet in the boat; I had to be careful because the carpet was very weather beating, later down the road I'll put new carpet in. It looks pretty good after I got done shampooing all the Alabama dirt out of it. I replaced all the wiring and then I took a look at the motor, I took all the old fuel out, changed all the fuel filters and spark plugs, the motor would crank over but it would not start. I don?t know anything about this motor so I took it to a friend that works on outboard motors. My friend Jim found the problem it was the fuel pump as you can see in the pictures the fuel pump is shot because the boat sat for about 2 1/2 years and condensation formed in the fuel pump, He's going to replace the hole thing because at the bottom of it, there is a screw that is stuck, Jim said it is best to get a new one because it will be under warranty. The other pictures show what happened to the fender when I had a blow out on the freeway towing it to Jim?s. The total cost for this plus Jim's labor ran me $1011.24 THANK GOD FOR MY TAXES. Know it?s time for the bunk boards. I dropped my boat off at my friend?s house in Hesperia, so he can reinforce the bolster brackets and help me put on the new bunk boards, as you can see in one of the pick the center of the bolster bracket is gone, he fixed that with no problem. There is one thing about this boat is I love is that it's all alum there is not one pice of wood.
Starting to clean up the boat
BASSNUT67
Re: My Rhino V176 All Alum Suzuki 4 Stroke Df-70
More cleaning
BASSNUT67
Fixing bolster brackets
BASSNUT67
know the fun begins, taking out the old carpet and glue
BASSNUT67
More clean up
BASSNUT67
Cleaning up the Alum
BASSNUT67
More cleaning
BASSNUT67
More cleaning
BASSNUT67
As you can see in the pic's I can't get in between the livewell and the side wall, so I closed it up.
BASSNUT67
My rod locker was only made to hold 6ft rods, here is the problem, all my rods are 7ft, as you can see in the pics I had to cut the top off to get to the alum plate, once I cut that alum plate away, this gave me plenty of room to install the new rod tubes.
BASSNUT67
Cutting out the carpet and making sure it all fits before I glue it all down
BASSNUT67
Sorry for all the post of only 6 photos at a time, it won't let me post anymore then that because I'm new:mad:
BASSNUT67
Putting carpet on the lids
BASSNUT67
Know the main carpet going down
