My simple pressure tester fot lower units ( photos )
kodibass
things needed to build
2 5" section of 3/8 braided fuel hose
1 2" metal tire valve stem
1 Brass T fitting
2 couplers For T to hose connection
1 2" Aluminum bolt & aluminum ny-lock nut
1 3/8 o-ring
4 small hose clamps
The aluminum bolt & nut are available at auto parts stores
DIRECTIONS: cut head off aluminum bolt place bolt in a vise and drill thru lengthwise. thread ny-lock on to bolt backwards then put on o-ring. place coupler in brass T and hook up both hoses, push metal tire valve in one hose & bolt set up in other. clamp with clamps. screw on gauge and its done.
use a tire pump or hook a tire air chuck to your air compressor and give it a couple quick shots.
raczekp1
Re: My simple pressure tester fot lower units ( photos )
what about the preasure, when you pump air is ok, but is there any reverse valve to stop air to go back when you relase conector from air compressor or air pump?
kodibass
Yes the schrader valve stops the air from flowing out just like a inflated tire. to release the pressure just push on the schrader stem.
kodibass
keefallan
That's great!! What are the threads (size and tpi) for evinrude lower units. I will make one of these but, I've never paid attention to the threads on the lower unit fill screws.
The tester looks great and the price is right but what are you testing? Maybe I need another cup of coffee.
keefallan
Its to test a lower unit for water leaks. If air gets out, water will get in. I just don't know the thread sizes for the lower unit plugs.
kodibass
the above tester bolt I used was 3/8 nc 16 tpi you can use a wrap or 3 of teflon tape if it seems a bit loose. I used a extra thick o-ring as well, the gauge was off of a old discarded air compressor. kodibass
Vintin
What is the suggested test pressure?
kenmyfam
Nice job.
boobie
Start out with 6-8 psi and let it sit for 10 minutes and then go to 14-16 psi and again let sit for 10 minutes. If there is a drop put in a tub of water to find the leak. Soapy water also works good.
64osby
Nice and simple, good job KB.
