Re: My spark plugs are wet
Yes, same problem. Will start and idle fine, and runs fine up to about half throttle. When you hammer down to get up on plane, it sounds as if it's either not getting fuel correctly or it's not hitting on a cylinders. Compression checked out fine, 125, 126, 126, 121 and I changed plugs, which helped a little. <br /><br />I am barely able to get the 16' welded aluminum boat on plane, whereas before I was getting low 30's with it.<br /><br />As far as the oil is concerned, I used Penzoil TCW-3, so I don't think it would cause problems. I've heard it could be a stuck needle on the carb, busted diaphram on the fuel pump, bad switchbox, bad stator, bad coil, etc., but right now I am trying to go through the cheap stuff like fuel delivery. My plugs are as yours are, wet with fuel/oil mix.
