hotrod53
Thread starter- Joined
- Oct 16, 2009
- 509
1977 Mercury 500, thunderbolt ignition, 4 cylinder, no distributor, new plugs, new fuel line from the tank to the fitting but not inside the power head, full tank of fuel, StarTron treatment in the mix. The last 4 years it ran flawless, this year its been in the water for 4 hours and today it all went bad.
I'm at full throttle heading upstream for about 2 miles. My pee stream is good, no issues there, no weird noises. All of a sudden I went to half power as if I lost a cylinder for about 10 seconds, then 1/4 power, then not much power at all. I checked and I still had a good pee stream. I then went to neutral and it idled but not well. I tried to power up and it tried, then went down on power, then very low. I turned off the motor and let it sit for few, then I cranked it to see if it was free, no issues there. I pumped the ball and tried to start it, it sounded like it was flooded. Later on down the river, I could get it to try and start with the enricher all the way up but no good. Problem was I was 7 miles from my dock and my trolling battery was going quick! I had to call my brother and get rescued.... thank goodness for cell phones!
I'm thinking new fuel lines inside the power head to start, check the plugs which are new, maybe rebuild the fuel pump. Any more suggestions? And yes, a compression test may be in order.
