My VP 4.3 GL and Starter
charlie1900
Hi guys, i;m new to this site and I hope I can get some help. I have a 2006 chapparell with a 4.3 gl volvo penta and I'm having starter problems
Before when I tried to start the engine, i was just getting a clicking noise so I had the starter replaced. Now that i have installed the new starter, I am not getting anything, not even a click. When I turn the key ahead, my power trim isn't even working. I am wondering is there a fuse somewhere that could be causing this or another switch. Thanks.
GA_Boater
Welcome aboard.
Moved your post to a new thread out of the old one. Look at the Help Tip on top of the page.
What kind of shape is the battery in? A discharged or weak battery also just clicks the starter/solenoid.
alldodge
Howdy
Look for the 40 amp push button breaker on the motor.
Other wise need to start with a voltmeter and start tracing your wires. Do you have a battery switch and is it ON?
charlie1900
yes it has a battery switch and its on and is the breaker your talking about is that the one above the battery switch
also my power trim ,radio and bielge pump aren't workin now either
charlie1900
one more thing I am new to this forum and can't seem to figure out how to post a new thread thanks for any help
alldodge
The breaker is on the engine and has a red button. Looks like its probably a 50amp instead of 40. Need a volt meter or test light and follow it to the alternator and then thru the breaker. See lower left side of diagram below
make sure your connections at the starter are bright and shiney clean. as in clean enough that you would eat off them. Same goes for the battery connections.
