bktheking
- Joined
- Jul 29, 2008
- 5,057
Well - it runs- had the lower off today, no water in the gearcase, pumps at first startup then it stops pumping. Took 30 pulls to get it going. Ran it for 2 minutes, after 30 seconds water stopped coming out the exhaust hole. Shut it down, put compressed air up through the exhaust then restarted it, started pumping again then ran out of gas. I filled up the tank then it wouldn't restart. So I decided to call it a day and put it on the stand. I'm thinking at this point it's getting water in the cylinder so I pulled a plug and pulled it over a couple of times to check well wouldn't ya know it the friggen thing fires up. I put the plug back in, starts first pull?????WTF, i'm thinking a powerhead gasket issue at this point...
