Myacht
Bheck11
I have a 1997 Myacht that list to the port side aft. Anyone have a solution?
Silvertip
Honorary Supreme Mariner
Underway, at the dock, cruising, no wake, what???? Have you checked the loading? Too much weight on one side? Water trapped in a void on the heavy side. We can't see your boat so you need to be our eyes.
Bheck11
It’s all the time. There is a void on the heavy side but sure doesn’t seem like a lot of water in there. When I first started looking for solutions there was someone saying the same thing from like 2014. Said he had to pump out every couple days. Thank you for getting back to mesilvertip
airshot
My guess is the water should not be there whether a lot or a little !! Remove the water and fix the leak, then you will know for sure..
SJColorado
We have a 2001 and had same issue. We had it removed from the water and found several pinhead-sized holes in port side pontoon. After emptying pontoon, welded and no problems since. Good luck!
