- Joined
- Mar 8, 2009
- 43,596
Do you think the grounding them important for the elec. output readings or just to keep it from starting?
Don't know if it will change the readings, just protect against sparks around gas fumes, or something else, just reading info. As for the grounds, this is what I'm use to seeing bolted to the block to connect plug wires to when not attached to plugs
