Mystery cylinder problem, HELP needed! 1971 Evinrude Misfire on idle
Sander
Re: Mystery cylinder problem, HELP needed! 1971 Evinrude
It is very hard to find a mechanic that actually knows anything here. Since it is an older outboard, a lot of them wont even touch it.
I have the carbs apart and will start with cleaning, also I am replacing the coil, and all plug wires. Once the carbs are back I will link&sync according to my manual.
If the problem still persists, I going to most likely give up and accept my losses.
194269
OK, I am going to through some thing out there. I have owned many V-4's that where built during the late 60's and early 70's. The 1969 -1971 V-4's came with adjustable idle jets and they like to move. I had a 115 and a 125 which started to drop #3 and found out it was due to an over rich problem on the idle system. Mainly the idle needle backed out causing the over rich condition. Reset all needles to 1 turn out and problem went away. The nylon lock nuts loosen up over time, allowing the idle needles to move, causing a over rich condiction even at WOT. Just my .03 worth.
Sander
I think this is spot on my friend, as I just took my carb apart one of the seating's for the slow speed needle is completely dissolved!
As this is no longer a cylinder problem, yet a carb issue I have created new thread.
Take a look : http://forums.iboats.com/showthread.php?t=512212
jigngrub
What did I tell you back at the very beginning Sander, back in the main forum on your "What to do if you get stuck on the water" thread?:rolleyes:
I'll agree, good mechanics are very hard to find... but when you do find one he'll be worth his weight in gold some times.
I hope you get this motor fixed up and it runs real good for you, it sounds like you're on your way to a solution.
Sander
PROBLEM SOLVED :
After removing and cleaning both carbs, I found the slow speed needle seating's where deteriorated. Using the new RED seating's with proper needle adjustments the motor runs and idles fine. Cylinder #3 woke up and works great.
Cause of the problem as followed : The bad needles seating were causing an over rich condition and possibly flooding cylinder #3. I hope this will help someone in the future.
THANK YOU FOR ALL THE HELP GUYS. AND A SPECIAL THANKS GOES OUT TO 194269 FOR BEING SPOT ON.
OLD NEEDLE SEATING FOR REFERENCE :
