1997 Merc Force 120 ELPT running Champion surface plugs UL77V (manual calls for L76V). Came across an odd issue with one of the spark plugs. When in doubt, ask away, so here I am.
Got this boat last week, yesterday did a compression test and all strong within a 10% margin. But as I removed the plugs I noticed some inconsistencies with their condition, took pics for safe keep. What caught my eye was how wet/grimy #2 from the top is, and how dry #4 is (bottom plug).
Here's the puzzling part. Today I cleaned the plugs and gave them a very light sanding, installed, run the motor for a couple of minutes and removed the plugs to do an inspection. All the plugs except for #2 had a ring of unburned fuel in them, which is what you'd expect. But #2 was dry. Swapped the plugs, run the same test and once again #2 was dry. Thinking that maybe it didn't have a spark I swapped wires (wire and module). While I had the wire harness for cyl 1 and 2 out, I run them past the Ohmmeter and both checked out, as well as continuity. But I swapped them around anyway, since they're the same part number and same length. Run the motor for a bit and once again the plug pulled from cyl #2 was dry.
Fearing that I had a cylinder that wasn't firing I run the motor and pulled the top plug's wire and noted the immediate reaction of an engine running on 3 cyl. Run the same test but this time I pulled the wire for the questionable cylinder. Motor immediately choked as expected. So the cylinder does work, it is kicking. Should also point that while running it sounds beautiful with no signs of anything being amiss.
So what gives? Why is that plug dry after running the motor for a few minutes while all the others have a ring of unburned fuel in them? Note the pic below and how wet #2 is, which is the complete opposite of the results I’m getting. May be a non issue or it could point to something else, like not enough fuel getting into the combustion chamber or perhaps timing that’s off?
