Home Cookin'
Thread starter- Joined
- May 26, 2009
- 9,715
last weekend the motor (150 hp) started acting stupid--dying down like running out of gas; when pumping the bulb it would stay soft or even collapse and not recover quickly. Then it would get gas and run fine for 5 minutes or so. This was after about 3 hours of running fine. Hairy crossing the shipping channel in the harbor!
So I figured fuel pick-up but I was also hearing a possible air leak. I started in the motor with its filter--OK, and replaced the water seperator (about 50 hours and 7 months on it). replaced the bulb and the line from the tank. unscrewed the tank barb and it was OK; anti-syphon valve seemed OK. I was hoping I wouldn't have to pull up the sealed deck to get to the pick-up tune; the floor hatch is just an inch off so you have to. But the problem peristed.
I pulled up the plate, unscrewed the pickup tube fitting. no apparent blockage and it held the fuel in it like a soda straw. reinstalled, resealed, boat seems to run fine.
So if it was an air leak, would that cause the bulb to stay collapsed when you squeeze it while running?
If it was a blockage (usually a piece of tinfoil from the top of a stabil bottle) I guess it's still in there, lurking, waiting to get me one night in bad conditions?
there wasn't any way to look into the tank through the pick-up hole and the fuel gauge hole is a couple feet away (80 gallon tank).
thoughts? Or do I just keep my fingers crossed?
