Mystery Gearcase O ring in kit for Johnson '57 RDE19
DavesInvader
Hi folks
I have the Sierra Gearcase Seal kit 18-2686 for my '57 Johnson RDE19 35HP
Lower Unit Gear Housing Seal Kit for Johnson/Evinrude, GLM 87607 - Sierra - iboats
I've found a place for everything in the kit except for one little o-ring. About 1/4" across, it's the smallest one in the kit.
At first I thought it was the O ring that goes with the bushing for the shifter rod, but that one's bigger and fatter. Any ideas where this thing goes?
Thank you!
Dave
seahorse5
Re: Mystery Gearcase O ring in kit for Johnson '57 RDE19
under the Phillips screw that is the shift yoke pivot ?
HighTrim
Definitely for the Phillips head screw.
F_R
Phillips head screw...BUT...some used a small flat gasket and some used an o-ring. So, the kit gives you both. Use the one that is appropriate, never both.
