I have a 1974 135 HP Evinrude that is leaking oil from where the Upper and lower units connect. It's not gear lube and the lower unit is okay. I know that the unburnt 2 cycle oil should be coming out of the exhaust and also the weep holes, but there is a LOT more coming out than what I think should be. Any advice?
Also I keep fouling the plug on the same cylinder. Compression is good but the same plug keeps going. I am mixing 50:1 Timing/New idle jets???
And the last issue is a vibration at idle. It started after I got my lower unit rebuilt last year. as soon as I pick it up from idle it stops, but when I'm trolling at idle it shakes the entire boat. Any guesses on the cause of that would help too.
Thanks ALL!
Thanks ALL!
