Mystery Oil / Seafoam added to 50:1 mix?
camawelander
Do you add the de-carb additive to the 50:1 mixed fuel..... or is the additive replacing the 2 stroke oil and mixed with the gasoline as per the instructions on the bottle.....
thanks
chuckz
Re: Mystery Oil / Seafoam added to 50:1 mix?
Add to the 50:1 mix. There used to be a very good step by step in one of the general discussion forums. Search for engine decarb and see if you can find it.
Scaaty
Never substitute the 50-1 with anything but TCW oil..just add to the MM/SF to the mix ..
