Mystery Part from 1986 Evinrude 15
kbait
Re: Mystery Part from 1986 Evinrude 15
They will interchange. Same part numbers.. 582285
Stumpalump
Mine cut out like the kill switch was pulled and the fuel primer bulb felt normal. Pull the fuel line off at the engine connector and pump the bulb about 5 times. That will flush the ethanol gum from the bulb valves and the stream should be very strong. If not you can pull the ends out of the bulb to clean the valves. That fixed my last "electrical" problem.
TomRay
I only buy ethanol-free gasoline for all my small engines. It was running from fresh fuel in a new plastic tank when it quit.
