brodie123
- Joined
- May 4, 2008
- 279
with help from the good folks here, I have my transom apart to get at the steering and do a few other maint items (seals etc)
One of the main reasons I pulled the whole asmbly apart was a slack between the steering link rod and the bell housing. I expected the upper swivel shaft pin (correct term?) to be worn.
With the bell housing off the boat - I held my hand on the swivel pin and experienced confirmed slack on the shift arm. The swivel pin did not move in the gimble.
I pulled the steering rod and pin. I do not see 'any' wear or signs of slack (tight as could be when I put them back together on their own. The pin does how some rust (very minimal - surface) on the lower splines. I inspected the splines on the gimble and see no signs of wear.
Where is the slack???
