Name That Part...
l008com
Anyone know what this metal bar is all about? As far as I can tell, there is nothing attatched to it. There hasn't been anything attached to it for as long as we've had this boat. The metal is worn a little, like it has been used for something, once. I'm just going to yank it out and fill in the holes. BUT I wanted to check first, to make sure that piece isn't the one piece that holds the whole boat together :D
l008com
Re: Name That Part...
To be clear, I'm referring to the metal bar that is horizontal in the picture. It has two hexagonal screw/bolts holding it to the little sub floor area that leads to be bilge.
fat fanny
IMHO That isn't anything factory if your not using it toss it!
scoutabout
Interesting. Possibly part of the mounting system for a long-gone ski pylon?
l008com
Its actually completely covered up by the back of the boat. Plus, there are no unexplained holes where the rest of it would mount. I dunno, very odd.
scoutabout
Hmmm - someone's previous attempt to keep the gas tanks from sliding around? (Unless you have a permanent one mounted further forward...?)
l008com
My tank has always lived to the right of this hole. I wish I knew what the rest of this mount looked like, if that's what it was. I want to upgrade to a 10 or 12 gallon tank, and I need to secure it, and build some kind of support as a bigger tank will overhang this pit. But that's another thread... As for this piece of metal... it's going bye bye.
Bob_VT
It holds the boat down onto the water!!! Remove it and the boat could fly away similar to releasing a kids helium balloon on a string!! :D
Beyond that guess...... I have no idea. If it is not hurting anything, not leaking and out of sight........ ignore it and go boating!!
oops!
its a flattend out used up roundtuit.
they used that to hold a tank or other item in place.
but what ever it held .......is gone now
roundtuit's only work once.....then you gotta get new ones
lil buggy
ok i'll play,
battery tie down,,:facepalm: , but i lked the kid and the balloon thought:D.
just toss it. just make sure you put 5200 or some kinda sillycone in the holes so the water cant get in there
woody66912
That is the oil tank hold down bracket for a OMC VRO oil tank. Take it out.
Philster
Leave it alone. Nothing good can come from tinkering with it.
oregoncruiser
I think the boat needs a matching one the other side!! Lol!!!
Seriously, I'd scrap it.
tnriver
Arrrrg, that would be to hold yea pirate booty chest or yar Rum keg'r.
Home Cookin'
if it ain't broke,fix it until it is. I'd leave it alone unless it's in the way.
mommicked
I was wrong, I thought it was a thingamajig or a whatumacallit. :facepalm:
