Name that tool!
ezbtr
Re: Name that tool!
Oh yeah, well I've had this one for years and know where I found it(would maybe give it away), and I have a SLIGHT idea what it is...... :)
ezbtr
Re: Name that tool!
And this I definitely know what it is...................any takers?
beezee28
Re: Name that tool!
ezbrt,
That looks like the underside of a flatbed scanner with adapter for photo negative. The other thing looks like 3 screws and a metal piece with holes in it. How did I do?
ezbtr
Re: Name that tool!
yup I scanned both.............ok sure screws...............what is it's purpose??????
ThumbPkr
Re: Name that tool!
I recognize the monkey wrench,in fact I am sure I have one around here some place but the screws gadget has me bumfoozled.Ron G
Bob_VT
Re: Name that tool!
Oh man the collectors value of that must be off the chart :eek:
Isn't that the infamous LEFT HANDED MONKEY WRENCH !!!!
slia67
Re: Name that tool!
Oh man, that reminds me of a story...
I used to work with this older mechanic who was telling the story. They were working on his son-in-laws car. The SIL was using a metric wrench to take a metric bolt out.
Gordon looks at his SIL and said, "You know I've got metric sockets back there in the tool box."
SIL replies, "Yeah, I found the sockets but I couldn't find the metric ratchet." :confused:
Gordon replies (obviously with a smile), "OK, then keep using the wrench."
ThumbPkr
Re: Name that tool!
I think they used to call them a Ford wrench too.....Ron G
itstippy
Re: Name that tool!
All the tools are marked with orange paint. This fellow must have spent 50 years working in shared shop areas. Marking your tools with paint is an old mechanic's trick to keep them from walking off. The larger, more expensive tools are also engraved with his name or initials. And orange paint. There are hundreds of tools and all of them (every last dang socket and allen wrench) is marked with orange paint and years of old, solidified grease. I have been cleaning tools every night for 2 weeks. When I'm done I will clean and restore the box (an old Snapon upper and lower). I'm a happy man with my Winter project in the warm basement laundryroom. The shop in my garage is at -2 degrees as I type; not good conditions for working on boats and outboards.
The hacksaw does have a wingnut blade holder for the front, and had a blade mounted when I started. The wingnut holder was still in the parts washer when I took the pic. So the angle iron mystery is solved! This was his sheetmetal hacksaw (there are three hacksaws, each with a different tooth pattern to the blade). It makes sense that the square head T wrenches are for gas or air valves. Drainplugs do not require the reach that a T handle provides. You don't situate a drain plug so that the liquid drains through obstructions. But bleeder valves for compressed gasses may have hoses or something in the way, and a T handle would be handy. On to more tools. I'm still in the homemade and modified batch.
Here we have a set of what seem like homemade car interior door panel tools, but much more substantial. These are heavy steel - no flex to them. Are they common configurations for working with sheetmetal, maybe?
Next is an oldfashioned 1/2" hex drive handle that's been majorly modified. I know what 1/2" hex drive sockets and handles are, but this handle has been reworked in a peculiar way. The entire shaft has been carefully ground down on each of the six sides to make it less than 1/2", and uniform in all directions. The end of the drive head has been shaved down and the retaining ball driven in. The elbow of the head has been ground down, as if to gain clearance for some reason. Weird. Why?
PS - yup, a cat habitat is correct. It sits next to my compter desk. Tippy and Bullitt keep me company while I surf the net and catch up on the iBoats Evinrude & Johnson and Boat Building and Non-Boating Technical forums.
puddle jumper
Re: Name that tool!
The first ones look like home made brake adjusting tools. The last one looks like a right angle screw diver. Use to be popular in the old tool box.
Nos4r2
Re: Name that tool!
I think most of them are called George.
However, there's at least one Hubert in there.
cbac
Re: Name that tool!
:cool: I pegged the cat habitat!!!
I can see the hacksaw for sheetmetal now. I was thinking in a cutting hot metal manner but using it for sheetmetal and the guard protecting the hand...ok same concept > hand protection.
ezbtr
Re: Name that tool!
ok the screw "gadget" used to keep my knee together....... :) muahhhhhhh.
The other I found at some stables behind my old house, not sure what it does.....
itstippy
Re: Name that tool!
Moving right along . . .
Here we have a couple of what look like electrical tools, about 8" long. I'm guessing for working on a vehicle's fuse panel? Molded plastic tips with odd shapes. Are they generic "fuse and relay pullers" or do they have more specific purpose?
Next, an odd crimper about 12" long. Quite solid. It looks like a baby version of a tool I used years ago in a lumberyard to crimp metal clips that held the steel bands we used to secure bunks of lumber. Some sort of clip crimper for banding bunks of pencils or popsicle sticks?
Bob_VT
Re: Name that tool!
The red and yellow ones look to be spark plug boot removal tools (I have a snap on one that I had to purchase for special plugs deep inside a valve cover) so you do nor dislodge the wire from the plug boot.
The crimper ..... I am just guessing is used for crimping hose clamps. I am sure you have seen the crimped on clamps on coolant lines.... the same ones we all replace with the screw on ones. AND it it also used to crimp bands on CV boots. You can buy the bands at NAPA.
jimr
Re: Name that tool!
Bob hit the last 2 plug boot pliers and CV boot clamp pliers
