jpmurphy
Thread starter- Joined
- Jan 14, 2009
- 358
I'm in the process of swapping out the old controls for the new controls that came with my new outboard. I have a Nav Light switch next to the console "dash" that is not part of the control box. After playing around with the lights and the wires I managed to get both the stern and bow lights to work. Now, this nav light switch is a three position switch. On, Off, On.
I think the switch is upside down as both lights come on when the switch is put in the "back" position. No problem. The problem is the switch is corroded and the lights will flicker on and off and finally off. Jiggling the switch a bit and the lights come back on. So, I need to replace this switch.
Now, this switch has 4 male terminals on the back side. Only 3 of the terminals are being used. When I replace this switch, can I use one that has 3 terminals ? Seems to me I could, unless the 4th terminal is for "future use", like possibly a courtesy light ? Which I have on order.
I've looked at the switches in the iboats store and I'm a little confused by the "momentary" references. To me, it's either on or it's off. Whats "momentary" all about ?
Am I correct in thinking that with a 3 position switch, both stern & bow lights are on in one position, both off in the next position, and just the stern (anchor) light on in the 3rd position. ??? This appears to be what my switch is doing, but with the condition of the switch I'm just not sure.
Also, I always thought that positive was red and negative black. Did this change while I was away ? My light wiring, just the 2 nav lights, has the inline 30 amp fuse at the battery on the black wire. This looks like factory wiring but who knows ??????
Appreciate any guidance.
