southpause
- Joined
- Jul 7, 2005
- 4
My 2001 Yamaha 2 stroke 40 experienced a catastrophic failure this past weekend. Mechanic says fuel pump apparently failed, causing loss of cylinder #3, with the sleeve severely scored. Cost of replacing entire new head and exttraneous parts is more than cost of a new Yamaha 40hp. (About 4 thousand) None of the safeguards designed to protect the engine kicked in. <br />Here's my question: would it be worth the money and effort to pay this O/B mechanic to reassemble the O/B, take it an authorized Yamaha dealer to see if the manufacturer might make a goodwill adjustment to pick up part of the tab for this?<br />The O/B probably has fewer than 30 hours and is used on my Zodiac RIB inflatable.<br />(The reason I didn't take it to an authorized repairman in the first place is because when it froze up, it appeared to be a simple electrical problem, because it wouldn't turn over.)
