Need 1980 Chrysler Sea King plug and oil mix info
sidthekid
Does anyone know the proper plug and gap for this motor? Also, what is the premix ratio? Thanks...Sid
This is a 7.5 hp motor.
cprince
Re: Need 1980 Chrysler Sea King plug and oil mix info
"...Very early engines were 16:1, then it was 24:1, and finally 50:1 (this switch was in the 60s I believe)."
Depending on the HP of your motor... .030 should be a good place to start for you gap...
***EDIT***
Scratch that! I am reading from .060 to .090 on a chart I found; http://www.newbridgeauto.com/download/AJK_Spark Plug Application & XRef.pdf
Scroll down to the outboard section near the bottom.
CRP
