Lou C
- Joined
- Nov 10, 2002
- 14,537
The water issue is curious you should be able to put your muffs on and see water come out of that water transfer hose as long as:
the muffs fit right (and some are too stiff to fit right, I had this problem with the dual inlet Tempo muffs I got a few years ago). I wound up switching to the Merc/Quicksilver ones that are made of softer rubber and fit better.
and, the water tube grommets inside the drive are in good shape.
The fact that the engine does not over heat suggests that the issue you are seeing is due to less that perfect fitting muffs. It runs at normal temp in the water, correct? 160-175?
next I’d be very curious to find out what if any specs are different from the original engine and what MM sold you...
lastly are you SURE there are no vacuum leaks around the intake manifold? Ever hear a hissing sound? The intake gaskets on Vortec engines can be problematic...
sorry I just have no experience with marine EFI engines, only familiar with old school carbs (Quadrajets and Holleys).
