Need a few outboard fuel tank parts
aaarneson
I am looking for a few parts for an outboard fuel tank. It is just the regular 6 gallon type fuel tank. But what I need I can not find...I have checked a few local marine shops and they couldn't help me at all.
I attached a picture to help explain what I need. I have the brass part, but I need the white adapter, the black fuel line, and the red fuel filter.
Does anyone know where I can get these parts?
esobofh
Re: Need a few outboard fuel tank parts
i've only ever seen the inner tank components come with a new tank.. good luck!
Frank Acampora
It is a standard threaded part, I think 1/4 NPT. Just use a standard brass 90 degree fitting you can buy at Lowes or Home Depot. Solder in a brass tube in the bottom to accept the fuel hose and you are good to go. Total cost 2-3 bucks.
Any 1/4 inside diam. fuel line will do, and the in tank strainer is not necessary if you use an external filter.
